The HSE information sheet 16 covers the subject.
http://www.hse.gov.uk/pubns/wis16.pdf
But the main points are
The blade "be set so that the teeth project through the surface of the material during cutting"
"A circular saw should not be used for cutting a rebate
or groove unless the blade is effectively guarded.
This is because the normal saw guard cannot be used. Suitable alternative guards and fixtures are necessary. Figure 8 shows an example of one method for rebating or grooving using Shaw guards. Where practicable, the tunnel formed by the pressure pads should be designed to meet the requirements of BS EN ISO 13857:2008.7"
"Stopped grooving should not be done on a circular sawing machine. This should be done on a vertical spindle moulding machine or a hand/pin routing machine."
"This information sheet contains notes on good practice which are not compulsory but which you may find helpful in considering what you need to do."
These regs are updated from the 1974 and came into effect when the Acops and Puwer regs were launched back in the late 1990's. At that time I was running the workshops in a college and was sent on a HSE training course to ensure our college was working within the law.
As part of the training we were reminded of the "good practice which are not compulsory" statement but if an accident were to happen you would not be able to argue your case if you had not worked within the subscribed "good practise" and we had to write safe systems of work and risk assessments.
All very tedious but it did make us very conscious of the risks involved in wood machining and that we are responsible for the people we teach or manage.
Anyone who has been in woodworking for some time may have been involved or witnessed some accidents over the years, and it does focus your mind if you have been involved!
What you do in your own home workshop's is your own risk, and I do understand the commercial restraints involved in running a small business I run two.
But the regs are there to try and keep you safe and who wants to loose their fingers or worse?
We run very practical short courses on wood machining highlighting best practice and keeping your self safe, but using the machines to their full capabilities of accuracy and productivity.
let's be carful out there
That's my sermon for this Sunday morning!
Cheers Peter
