Noah's Ark
Doris
Oppressed Slave of Gary The Cat
10 Jul 2011
Essex UK
Hi Everyone,
This is my first carving project I have shared on here and have been keeping more photos on it's progress than other projects I have done in the past. So I thought I would make this thread on it.
A couple of weeks ago I received a text message from a very good friend of mine who was fitting a new kitchen sink into his worktop. It was solid oak and "was as hard as steel" and was asked if I wanted it otherwise it would be taken to the dump.
This is the picture I received with the message.
I said I would take it, although at the time had no idea what to do with it. While I awaited it's arrival I came up with the idea of using the worktop to help me create the hull of a small noah's ark. This is a project I have been wanting to do since I first took up carving and was in fact one of the reasons I did after seeing one in a shop window for several hundred pounds.
The plan was to lamiate the worktop together, using the lamiations from front to back (I'm not seaman so I'm sure someone will correct me with the proper term) to imitate the planking on the ark's hull.
When I received the top I had a bit of chipboard and screws to remove and then cut some excess bits off. You can see where I had started drawing on the wood to make sure my template for the hull fitted the worktop.
I then had to plane off 10 years worth of Danish oil using a woody jack plane, which proved to be easier than I thought.
The side profile template was then drawn onto the worktop
Then cut into it's sections. You can see that one of the laminations is running vertical, rather than horizontal. This wasn't a problem as I would hold this piece in the middle and wouldn't really be affected by the carving process as much as the others.
These were then glued together and left over night to dry.
After 24 hours the clamps came off and the top profile was ready to cut out. You can just make out the brown pencil marks on the deck and sides.
To do this on such a curved surface in a big bandsaw would be too dangerous and so mounted the ark to a piece of scrap plywood to hold the ark at a good and safer position.
Once roughed out, the f clamp I use to hold the work so my hands are well clear of the bandsaw blade.
I then used the two screw holes I had used to mount the plywood to then mount a mounting block to. (Although this proved pretty useless in the long run as the sides of the ark were pretty flat for my vice jaws to hold.)
The hull was then carved (Sorry I lost the picture of this) and then rasped to a more even finish.
Next I worked on the deck. A 1cm line was marked all the way around the deck and then this was carved out. I decided to leave part of the middle section with the end grain face to create a sort of tenon for the housing for the cabin.
The whole hull and deck were then sanded and cleaned up before work began on building the cabin. After much fettling on the deck the cabin was finally glued into place over the tenon.
More to come..... :)
Windows drilled in place.
Now gluing on the walnut trim at the top and then locking it in my carvers vice.
Have also started carving the animals from offcuts of ash. This is the first one.
No I think it might be the camera that has given it a pink tint.
I managed to carve a couple of elephants and another giraffe. The ark is now almost finished too. Just need to mount it.
Thank you
The ark I've made thankfully has a small deck Lol so won't need to carve as many as some have done. The larger ones will also take longer to do than the smaller ones.
Work has now began on the base to mount the ark.
I bored into the bottom of the ark using the holes that were use to mount the mounting block and made two 16mm holes into the hull. I then used the piece of plywood that I used to original bandsaw the arks shape to make the two corresponding holes in the base. These then had two holes bored into them using a 15mm forstner bit. Two lengths of 16mm dowel (salvaged from something I was about to throw out) were then glued into the base (not the ark end yet as I would need to remove it to work more on the base).
I wanted to add waves to encase the ark. So I took some offcuts of softwood left over from Dave’s current project and ripped these in half. I then band saw'd waves out of them.
These were then sanded and painted.
Then glued into place.
Gold paint was then added to the waves just to compliment the oak. Dave had suggested white at the top of the waves, but felt that this was too much and so opted for white. I was aiming for a folksy style and felt that gold would achieve this look much better.
Some of the animals I have carved so far.
Them on-board
TBH I had doubts about this while you were making it but seeing it now as an entire piece I think it's really nice and 'wantable' if that makes any sense.
I had wondered too about mounting it on dowels but it's clear that you knew what you were doing all along re. positioning the ark in all three dimensions with respect to the surrounding waves.
Interesting [I think] that there are flood myths in perhaps most ancient civilisations across far flung continents. http://en.wikipedia.org/wiki/Flood_myth
That is really nice. Do you haave any pics of how you carved the small animals? I have always wanted to try carving things like that but wouldn't know where to start!
H.
Ewe you should be very pleased with them and the entire Ark as well.
Very well done =D> =D> =D>
