DBT85
Ha, the self test is just to check that its correctly armed and ready to pop.Does this self test go the whole hog, each time it's started ?
If it does, that'll bring a whole new dimension to what was
already an expensive hobby.
Not much sawing would get done, either.
Of course it can't it works on conductivity. If you know you are cutting something conductive (rare enough) then you disable it. As soon as the machine turns off it re enables the arming mechanism.It can self test as much as it wants to, but I bet it still won’t know the difference between wet wood aluminium or your finger.
how wet does wood have to be to set it off?
I'm sure I saw a video of someone using one with exceedingly wet wood and it didn't go off as it wasn't conductive enough. It would probably have to be dripping.
The tech is only a good thing. It gets the usual "as yes BUT, now people will take more risks" from some people.
Naturally if the Felder solution works just as well without trashing an expensive blade and cartridge then even better.
