Hi All,
I'm fairly new to routing and have mainly used it in the table, for a garden table restoration i'm doing I needed to remove an old mortice and insert a repair piece in order to give me a secure fixing for a Domino prior to re-assembly.
The ideal solution seemed to be a guide bush and collar to cut out the bad wood and make the insert along with the repair piece.
I made my jig and then had to change it to allow for the offset of the collar (newbie mistake) but tried it on a bit of MDF before cutting the repair holes in the Teak table top. I ended up with a perfect cutout in the MDF with nice rounded corners but the infill piece once the collar was removed has square edges obviously as it was using the internal face of the cutter.
The infill piece is perfect apart it has square edges so doesn't fit perfectly. I'm happy to sand the repair pieces to fit as they won't be seen but wondering how to get a perfect infill that doesn't need sanding and fettling if possible.
I'm using a Trend T11 with a 10mm cutter, 20mm guide bush and a 20-40mm collar. I'll try and add some pics below.
Many thanks for any advice you can offer
Cheers,
Jon.
Cheers,
Jon.
