Mitch
Hi,
I’m new to this site and to woodworking so please forgive any daft ideas or questions. I have read through various threads here ( many thanks to all who have contributed) but can’t find anything which covers my idea.
I’m about to start a new build shed but on a very limited budget so am salvaging wood and materials (or buying very cheaply) where I can.
I have a slabbed area at the bottom of my garden which meets fences on the sides and a brick wall on a diagonal at the bottom (as in diagram).
The slabs have been down for some years and haven’t shifted. I added a row onto a solid hardcore base 15 years ago and I think the rest are cemented onto a similar base (or an old concrete Anderson shelter or similar) so I am fairly confident it will provide a solid base for the shed.
I’ve read Mike G’s posts and intend to follow his plans for the base (course of bricks to form a dwarf wall) and intend to lay quarry tiles (already have) for the shed floor.
I have the chance to get some 1m length 3in x3in fencepost offcuts cheaply and wondered whether I could use them for the shed walls.
The idea is to build a frame with 1m gaps between and then lay the offcuts horizontally between (as in diagram).
I haven’t seen anyone on else do this (and there’s probably a very good reason why not!) but my thinking is that this would form a 3in thick wooden wall which would not need further cladding outside or lining on the inside.
My main concern would be whether this is a goer structurally (would this be too heavy for foundations?) and in terms of water ingress.
If OK structurally, would the best way be to use mortar (as I’ve seen on cordwood buildings) between the posts (A in diagram) or butt them as tightly as possible and use some form of sealant (PVA? Silicone?) between (C in diagram). In both cases I’d probably use some nails or screws to fix them the frame as well . An alternative, if weight is an issue, would be a kind of half and half structure (B in the diagram).
Also, would I need to use any particular wood treatment on outside?
Any comments on the principle or the detail would be much appreciated.
Many thanks
Mike
Many thanks
Mike
