Hi can anyone help, i am building a workshop at the end of my garden and am unsure how to properly insulate it,
I am using 95x45 treated timber for the framing and was going to clad the outside with 11mm osb covered in breathable membrane then clad straight over the top with 16mm shiplap cladding, then on the inside fill walls with 100mm insulation slabs and then finish off with 18mm osb, then basically the same for the roof apart from covering it with corrugated roofing sheets .
I am concerned about condensation build up in the walls and roof space, do i need to vent the roof ,leave gaps ect or add vapour barrier to the walls ,
I could really do with some expert advice as the is so much mixed information out there as i am a bit lost ??????
Thanks Martyn.
Thanks Martyn.
