jamesmerrix
Hi,
I am planning to biuld a new workshop in the next few months and wanted to get peoples thoughts as to the best order to work through the project.
It is going to be about 4x8 - with a dividing wall about 2.5-3m from one end to create a home office as well.
It is going to be a timber frame building with a concrete floor, featheredge cladding and a slate roof.
After asking peoples advice regarding the windows i am going to get some UPVC windows (either new or second hand, depending on what pops up on ebay).
Insulation will probably be a mixture of rockwool (or equivilent) and PIR (probably from Seconds and co)
I think i am fairly happy with the first stages of the build:
please correct me if i am wrong...
Foundations - trench style filled with concrete
A few courses of bricks/blocks
Fill the base with hardcore, sand, DPM and then concrete
insulation
Screed
DPC over the brickwork
Timber frame to eaves height.
This is where I start to get a bit unsure;
roof structure?
underlay?
slates?
exterior wall cladding?
insulation?
internal coverings (OSB, plasterboard etc)?
windows/doors?
or should i get the walls and windows done before the roof and then finish with the insulation and interior covering?
I am sure that which ever way I picked I would end up with a usable space, but i would rather get it right first time so that i did not have to undo work in order to fit in a vital stage that i had forgotten!
Thanks in advance for your help.
james
insulation
Screed
roof structure?
underlay?
slates?
insulation?
windows/doors?
james
