stuckinthemud
I am a woodcarver not a joiner or furniture maker. This means several things that are relevant to making a new bench. I love small detailed work with hand tools, but don't enjoy planing or sanding large areas. I own a 20 year old hobby router, an asthmatic 600w b+d drill and an aldi/lidl belt sander I stripped the living room floor with and a jig saw from the same supplier. I can sand large surfaces, just don't enjoy it. I also have only 1 large clamp.Anyway, I have a couple of old pews, yellow pine, 14"x1 3/4 x 14ft I can laminate. I believe best practice is ripping the boards slightly over size (by jigsaw in this case) into 3 lengthwise strips to make the most efficient use of the boards, sand them to remove the varnish and laminate with pva to get a table around 4.5 inches thick. Would you bother sanding them (I'm guessing the answer is YES), would you sand then cut, or would you not sand but plane them down instead? Oh, the issue re clamps - suggestions ? I was wondering about using blocks and wedges?
