Hi,
I'm new to wood turning and would like to pick your brains.
I would like to turn small pieces of balsa wood from dowel, approx 8mm diameter and 15mm long diamond shape with a 1mm hole through the centre.
My questions are:
1. If I want to make the pieces as detailed above or similar all exactly the same how would I do it ??
2. Can I use tooling made to suit each piece I require ?? If so what would the tooling be made from, steel or grinding wheel ??
Thanks in advance for any replies.
Mark
My questions are:
Mark
