scholar
Forgive me if this is an ignorant question…
I am just recommissioning a bandsaw that I picked up recently - an Ixes Basa 7 which is the big brother to my Scheppach Basato 5-4 (which will shortly be surplus to requirements)).
Everything is in very good nick after a total strip down and clean - I think it has mostly had an easy life - but I am unsure about the motor.
The motor runs when switched on, but does seem rather noisy (bearings?). My first observation, though is that the motor will not turn by hand at all - this means you cannot spin the wheels by hand to true up the tracking when fitting a new blade, as I am used to doing.
The wheels on this saw are very heavy cast iron which is different to the lighter wheels on my Basato 5 and indeed my little Inca, but I would still expect the motor to turn (and to hum much more quietly when running).
So my ignorant question is: Is there any reason why the motor should be locked tight like this? (Eg a different braking arrangement?)
If it is OK like this, how does one true up the tracking? (you have to shut the door/cover to activate the safety switch before the motor will run, of course).
