New induction hob issues
Stoobydoo
New member
23 Feb 2025
Scotland
Hi everyone, I have just joined the site having found this thread: https://www.ukworkshop.co.uk/threads/induction-hob-issues.116298/
As it’s an old, 6 years old, thread, I was advised to start a new one.
Essentially I have exactly the same issue as the original poster. We have just had a new kitchen in and it’s perfect except for the new induction hob. We have a portable 2kw, single ring induction hob which is great. It can boil half a litre of water in 2 minutes. All our pots and pans work well with it.
it works so well that when we were planning the kitchen we thought we’d go for in induction hob. We ended up getting an AEG
IKE85751FB which is rated at 7.34kw and well, it is infuriating to use. It takes over 5 minutes to boil water in the same pots and pans and I’m wondering if it has a fault or not. The pots and pans are all induction hob compatible and as I mentioned, all work very well on the portable hob. I have no idea if the original poster is still about. I’d love to know if they found a resolution.
Stuart
Make sure the single phase link is fitted (assuming youre running single phase). It's stored in the terminal block area (see small red circle) but it's not fitted as standard.
Phil — my timings are with the P boost function. The wee portable would boil a mug in a minute but not the AEG.
Johnb80 - the electrician will be back and will get him to check.
Is it the shape/size of the pot? A little pan might fit exactly where the induction coils are on the portable, but miss them on the larger hob where they will be arranged in wider circle.
You can see where the coils are if you put a very flat based large pan on with a little bit of water. It'll start bubbling over each of the coils. If you only cover half of them you get half the heat.
We have a Belling range cooker with four plate induction hob, this boils very rapidly. Our belling has one "ring" with a powerful rating (larger ring) and three with lesser rating. All of the rings boil rapidly, depending on the pot (size not shape).
Have a look at the specification as to what each hob is rated at. Seems wrong to me, speed is the delight for me, this replaced a gas range cooker, no contest!
Some hobs output different power ratings dependent on how many amps they’re fed. Friend had one fitted in a holiday let and without running a new line back to the CU the hob would only run at a lower power and took longer.
Double check the manual and get the spark to check it’s getting the power it needs
Tom, that would be voltage not amps! I have just checked my Belling manual and three of the pan areas are 1.4KW and one 1.9KW. I have never used the boost control (which apparently "borrows" power from its pair, the LF &LR and RF & RR can be linked, upping the FR gives it 2.3KW). It does also explain that the heated area depends on the size of the pans base and gives minimum pan base size of 150mm for three and 180mm for the front right area. It would be interesting to know what your hob areas are rated at.
Tom is correct, it's amps, the flow of current. Assume all UK mains appliances are 240 volt. The circuits that feed them have different sized conductors and right back at the distribution board (fuse box) different sized circuit breakers. Typically 5 amp for lighting circuits, maybe 30 amp for hob and oven. 15 for power circuits. All are 240 volt.
A 7Kw hob, all zones on full, needs 30 amps.
It strikes me that power supply, current, is the most likely limiting factor here.
The other possibility is that the pans, although they work, just don't conduct heat well enough. I have one like that, it is non stick coated stainless steel with a mild steel sandwich base but the area if the sandwich bit is smaller than the pan diameter, useful for slow sauces if all the others are in use but no good at all for speed.
A quick thing for anyone thinking about an induction hob and wondering if their pans will work- an ordinary everyday magnet like a fridge magnet. If it sticks to the base it will work, if not then it won't. You can't just judge by material, lots of aluminium, stainless steel and others have a sandwich base to make them compatible.
So how does the hob "know" the size of the conductors or the rating of the breaker?
I'm not arguing with the principle that an induction hob needs a lot of amps, we have one, and also have a smart meter - I'm arguing with the idea that the hob would operate at lower power because it "knows" how many amps it's being fed. Amps aren't fed, they're drawn.
I agree with John Brown, the device can't know cable/ breaker size.
Each hob is a array of rings and induction hobs work by varying the frequency of the voltage supplied to the magnetic rings thereby changing the current drawn. If it is exceedes the cable's rating then the cable will overheat, at some point tripping the breaker.
At the lower settings it also cycles on and off to maintain a given temperature or power level. The handbook for my Belling cooker makes it clear that it does sense the size of the base, turning off rings (magnetic) outside of the base area. It also makes it clear if the wrong pot is used by not powering the ring and flashing an error signal. There are only two factors here the size and type of the pot's base and the rating of the individual hob at full power.
I am finding this interesting reading. Lost my gas hob a couple of weeks ago and cooking using an Ikea portable induction hob at the moment and I was really surprised how quick it boils water compared to the gas. I am having a new kitchen fitted in a couple of months with an induction hob and will keep an eye on the install.
Some simple things to remember, the protective device is there to protect the wiring not what is connected as the final load. A protective device such as a type B MCB will require 3 to 5 times it's rated current to disconnect so will not trip on overloads, ie a Hob requiring more current than what the circuit was designed for and so the wiring will get hotter and could lead to a thermal event. The best practice for the installation of ovens and hobs is to run them on their own radial from the consumer unit with it's own RCBO. Many modern ovens require a 16 amp supply as they are of european origin.
If the load is purely resistive with no reactive component.
AEG
So lets assume 30 amps, that will be 6mm cable, possibily 4mm if a short run and not chased in so considering this is a new hob then what has it been connected to in your kitchen ? Did you have an existing cooker supply ?
The cable really would need to be on the limits to have a thermal event. Type B doesnt need 3 to 5 x the rated current:-
At 1.5x the rated current, 100 seconds it will trip, at twice the rated current 10 seconds. You wouldn't create a thermal event in that time with that overload.
Agreed.
Induction hobs are very near unity, typically above 0.95
26amps continuous if plastered in, 37 amps if clipped to the surface. It's highly unlikely for the hob to take maximum current continuously for any length of time. I do agree better to be safe than sorry and 6mm would be a better choice for many reasons.
Thanks for the replies everyone. When the kitchen was planned it was clear we needed to upgrade the wiring and also our rcd. So, it should be up to the job. However, the installers have organised an AEG engineer to visit on the 8th. We should have our answers then.
In our case we have a double oven range cooker and if both ovens are being used (think Christmas) along with all of the hobs it could reach over 37A. Ours is on a 40A breaker.
But not continuosly due to diversity ie the ovens/rings cycle on and off to maintain temperature.
Cookers used to be 10amps plus 30% of the total demand, don't have a site guide to hand and you don't fit cookers in industrial settings . Thinking back there was also some additional if you had a socket on the cooker switch but I think that is now just history.
Also in the days of simple electric rings and ovens then simple on/off control was normal but now with these induction hobs has this been surpassed by some form of PWM modulation to deliver more precise control? These hobs work on electromagnetic induction so are going to be more complex and also will be using a much higher frequency so so form of power supply which could easily include power factor correction.
