Sir Percy":2747h833 said:Out of the box, though, would I need to file and square - just go straight to burnishing?
You can go with the veritas card scraper holder, it's better than plasterscustard":220c3w7w said:Percy, if this is for your wayward Sapele, remember you have to scrape evenly over the entire surface. If you just scrape in the area where there's tear out then you'll get a depression that'll be horribly obvious once the finish is applied.
Scraping properly is a lot of work I'm afraid, it's not the quick and cheerful solution it sometimes get painted here, you'll need plasters for your thumbs because the scraper gets very hot!
Good luck.
