Hi All
thanks very much for the encouragement!
I'll try to answer some questions. Unfortunately I didn’t take a whole bunch of photos during the process although I have one or two from a previous one, so I'll include a few of those.
Regarding materials, O1 is nice flat ground stock and I think it peins OK, but mild steel would be fine too. Some of the stainless steels might be OK but generally I think it's hard to machine, cut and drill and work hardens.
I followed the description by
http://www.handplane.com/30/making-plan ... lanes-101/ (scroll down a bit) . I got the basic design from Kingshott's book
https://www.amazon.com/Making-Modifying ... 0946819327 which I borrowed from the local library. This is also a good tutorial with some great photos.
http://www.petermcbride.com/metal_plane_making/. I followed this one for filing and locking the dovetails. I think this might be a neater process than the first reference - not sure if it is as strong though as you are hammering the brass into a steel notch rather than hammering the steel to lock the brass -if that makes sense. In the first plane (pictured below) I hammered the steel into the brass - the dovetails aren't as precise.
The first job was to cut the mouth which I did using a friend's milling machine. I can't remember much about that as it was 10 years ago. On the other plane, I filed the mouth and made the sole in 2 parts. That worked OK too.
I had the good fortune of visiting Philip Marcou (who makes exquisite planes) about the time I started on this and he generously gave me some bits of brass. That is why I'm not sure of the grade. But it peins without having to anneal it and you can bash it for ages without any signs of crumbling. It's important to get the right grade of brass. Someone else will know which grade or ask a metal supplier.
Then its a matter of cutting the shape with a hacksaw and files, using the interlocking approach described by petermcbride above. Needle files are really essential to get into the corners.
Peining is a bit trial and error. It'd pay to make a dovetail on a scrap before doing a plane. It’s not hard but getting them all without gaps takes a few goes. Mine aren’t perfect.
Make a solid former from hardwood. I used MDF for the latter one - I didn't like it as much but it worked OK.
The sides do spring back together a little after peining the dovetails so the advice to use a thin veneer packer in one of the references is a good idea.
Try to avoid denting the brass (if that is what you use). You can see rather a big ding in the side. Otherwise there is quite a bit of sanding to do and the walls get thinner! I avoided this on the new one by holding a bit of thin steel over the sides where I wasnt hammering or drilling an oversize hole in the steel an placing it over the rod I was peining.
I now have a small belt sander that made grinding the excess away a lot quicker. It can be done with files and emery paper (as I did on previous planes) but takes a bit of time and elbow grease!
I forgot to mention that the other key tool is a drill press. Mine is a fairly cheap one and it has to be set so its drilling perfectly square, especially when drilling through the block that becomes the lever cap. I also have an excellent small Record Engineering vice that hold the block of brass when drilling. And remember, keep a block of wood or something the right diameter in the plane when you pein the lever cap bearing rod (or what ever its called) otherwise it all locks up and you can't move the lever cap easily (which happened in this case even though I did have a lump of wood in the plane to try to stop this).
This is the finished first plane. As mentioned, its a really handy size and probably more useful than the bigger one - although not as pretty and certainly not as pretty as the Clifton
also made a shoulder plane some time ago - it was more demanding!!
Hope that helps. If I've omitted anything, please ask - but I'm no expert and most of it is covered much better in the references.
Richard
