- Joined
- 16 Nov 2021
- Messages
- 187
- Reaction score
- 57
Woodpeckers StealthStop
Introducing the StealthStop, a micro-adjustable flip stop that is ready for action. And the best part? It effortlessly flips out of the way when not needed. It's a game-changer! Designed to work within a 3/4" x 3/8" mitre track or channel.
Mount vertically for a convenient fence and adjustable stop system | Simple installation - bolt the brackets to track, then screw to the surface | Track can be mounted horizontally in the table for a flush surface | Rout a groove in your surface or use 1/2" plywood on either side |
Woodpeckers StealthStop 1219mm/48" Fence Kit - Left
| Woodpeckers StealthStop 1219mm/48" Fence Kit - Right
| Woodpeckers StealthStop (Pair) Micro-adjustable Flip Stops
There when you need them, gone when you don't!
Woodpeckers Iron-Grip Small Parts Holder
Improve your safety and increase your accuracy when routing small workpieces on your router table. Aircraft-grade aluminium jaws and a heavy-duty Acme-threaded steel vice screw ensure that your work is held securely.
£229.96
