Netto cheap tools
j
27 Sep 2005
Milton Keynes
Some cheap tools coming up in Netto from today
Here
Matt Emulsion - £4.99 each
Magnolia or Brilliant White
· 7.5 litre
Brilliant White Non-Drip Gloss - £1.99 each
· 750ml
Brilliant White Undercoat - £1.99 each
· 750ml
Painting Set - £4.99
· 13 piece
Halogen Lamp - £4.99 each
· 500W
· Power supply: 230V/50Hz
· Protection: IP54
Wet and Dry Grinder - £17.99 each
250W
Dry grinding stone:
· Diameter: 150mm
· Hole diameter: 12.7mm
· Thickness: 16mm
· Free rotation speed: 2,950rpm
Wet grinding stone:
· Diameter: 200mm
· Hole diameter: 20mm
· Thickness: 40mm
· Free rotation speed: 134rpm
Router - £12.99
· 1020W
· Voltage/frequency: 230V/50Hz
· Idle speed: 16,000-30,000rpm
· 6.35mm and 8mm collets (not included)
Router Table - £24.99 each
· Robust die-cut aluminium table
· Adjustable main fence, incorporating retracting cutter guard and
jointing fence
· Two steel table extensions
· Mitre gauge for angled cuts
· Feather boards and pressure pads
· Dust extraction port
· NVR switch for router
Router Bits - £9.99
· 20 piece set
Work Bench - £4.99
EVA Floor Mats - £4.99 per set
Safe, non-skid foam, ideal for fitness room, work area or play room
· Set of 4 2ft x 2ft high-density interlocking foam mats
· Covers 16 sq ft
· Easy to clean
· Water-resistant
· No adhesive required to install
Digital Caliper - £7.99 each
· Zero button
· Positive on/off switch
· No battery-consuming time delay
· Converts from metric to imperial
Assorted Fixing Kits - £2.99 each
Screw & Plug/Screw & Nail Set
· 620-piece assorted fixing kit
· 140 x wall plugs
· 80 x screw cups
· 45 x coach screws
· 355 x chipboard screws
Circular Saw with Laser - £19.99
1300W
· Blade size: 185mm x 16mm bore
· No-load speed: 4500rpm
· Cutting depth at 90º: 63mm
· Soft grip
Saw Blades - £3.99
· Set of 2
3-in-1 Tile Cutter - £9.99
Wallpaper Table - £19.99
· Foldable
Quick Clamps - £2.99
· Set of 4
Levelling Tool - £1.99
Ideal for picture hanging
Trimming Knife - £1.99
Trimming Knife Blades - 49p
· 6 pack
Not absolutely brilliant but for small work the clamps do not look to bad. Sadly we do not have a Netto's up here in Scotland other wise I would buy a few. :cry: :cry:
Mike
