SlowSteve
Hello All.
Mrs SlowSteve has commanded that there will be two very large units built into the kitchen - easy.
However, so that her delicate eyes do not fall on - and I quote - "all that clutter and tat" - ( which, it should be noted is almost entirely HER clutter and tat, although I shall not mention this as there are up coming tool purchases and fishing trips that may require approval and so I shall keep my peace..) the shelves need to essentially be turned into built in cupboards. The house is 100 years old and so there isn't a straight line in the house - so the idea is to build carcasses to get straight lines and hang doors from them
Again - easy enough. If this was garage grade work that its a weekends job.
But... each cupboard door is going to be somewhere in the region of 2400mm x 500m. Thems is big doors.
The simplist route would be to set to with some big sheets of MDF and have something Ikea like. My problem though is thats going to be very very dull.
Iff I make lovely cabinet doors by scaling up plans, my guess is that I am going to need to scale depths as well as widths and lengths and end up with some very heavy, very heavy LOOKING doors.
Would anyone be able to make any suggestions on what sort of options might be open to be to make something that looks good and a little refined but doesn't require block and tackle to install and isn't made out of 2x4's.
I'm also space limited, so anything that needs a lot of space, like building them as a torsion box etc - is going to bee tricky.
Thanks in advance.
Steve
Thanks in advance.
Steve
