jimwillsher
Hi all
ok first up, I’m DIY, not pro.
I have a Laguna Fusion 3 table saw, my first table saw. I am looking for a dado set. The spec says it’s a 30mm blade, but when I look at the saw it’s actually a much smaller arbor with a 30mm blade nut, and that blade nut is only wide enough for a single blade (though the screw thread is around 25mm long).
So I’m confused what dado I need. Should I get a 30mm dado with “spacers” (name?) or should I get a dado set based on the exact screw size, in which case what do I do about the blade nut?
Sorry if this is an odd question, but I want to be safe and don’t have the money to buy the wrong thing.
Many thanks.
Jim
Many thanks.
Jim
