...need bandsaw belt for Basato 5-2
lastminute
26 Apr 2009
West Yorkshire
I'm trying to locate a stockist who may have a drive belt for the above model.
Its the toothed belt (10mm x 1072mm) which links the motor pulley to the bandsaw blade wheels.
The m/c is in the Tech. department of a school...and gets a lot of use, so much so the teeth have worn completely away!!
Thanks for any advice.
Gerry
Have a look in your local Halfords or motor factors for something of similar size, there is usually a degree of adjustment possible on most machines so an exact match may not be necessary.
