My Homemade CNC
phooddaniel
31 Oct 2007
I am almost finished with my homemade CNC machine built from hardware store components and a couple of other elements. I videoed the entire process of the build so every little detail can be understood and viewed. I would love to get some feedback/comments/suggestions on the build. I will be returning to this thread to get feedback and discuss some enhancements that could be realized on the machine. There are close to 40 videos describing the entire process. The video process is at buildyourcnc website
Thanks,
Patrick Hood-Daniel
P.S. I'm currently videoing and describing the software toolchain.
Hi Patrick,
I shall look forward to seeing the video and anything that you produce using the CNC.
Paul
Welcome to the forum. I'm looking forward upon viewng what you've come up with!
Thanks for all the kind words.
I am getting ready to build a third machine that has a much stronger design and easier to build. Since all of the videos for the second machine are on my website, I will post the images of the third machine here and also post the images and video on the website.
The new machine will be almost exclusively in 1" and 3/4" pipe. Tools needed for this build will be a drill, a hack saw for cutting aluminum angle, and maybe a saw for very minimal MDF cutting. Stay tuned and check over at the website every so often.
buildyourcnc.com
I'm hoping a moderator comes by and removes the warning. In my opinion, this website is a very useful resource for the individuals here and I intend to use this forum extensively and provide rich content. Thanks, Patrick
motownmartin":18m64k7h said:
I'm sure it's a well worthwhile project.
Sure is Martin, have a looky here:
http://img.photobucket.com/albums/v47/M ... 0_0141.jpg
..and here:
http://img.photobucket.com/albums/v47/M ... 0_0142.jpg
This machine was built quite close to the plans laid out in Patrick's videos, but with a few minor adjustments to the cutting bed and the stand that it is placed upon.
Patrick builds his machine with the bare minimum of tools, so I'm quite sure that those of us with a plethora of equipment can knock one together in no time.
If anyone is interested, both Fecn and myself have some experience with building these machines & setting up the stepper motors/electronics kit from Motion Control Products Ltd. I'm sure I speak for the both of us when I say we'd be happy to help out where possible. :wink:
Regards,
Mick.
Hi Mick, thanks for the links.
This is a project I would love to do in the future, seeing fecn thread has made me realise that this sort of thing is within my reach but as you say would need help with the electronics.
When I say future I mean a couple of years, I need a new workshop first, it's no good having something like that without a big enough workshop.
It's actually not that big.
The bed is 48" X 24" and the top of the gantry is just over 25" above the base.(the Z-Axis stepper motor is roughly 3 1/2" higher) I'm a bit weedy and can lift it onto a workbench if required, but making the base cabinet has created some storage space for me, as you can see, so it's staying put.
The open design of the bed allows for unlimited lengths of material to be machined. One particular application that I can think of, where this machine could be indispensible, would be routing the rebates for treads & risers on a staircase, instead of subbing the work out. A pair of carcasses (Sorry, don't know the correct term) could be laid out & routed in a mirror configuration, moved up to the next set of steps & repeated until the staircase sides are completed. In the meantime, the treads & risers could be worked upon, whilst the machine is doing the donkey work.
Regards,
Mick.
would love to be able to make one... cant wait for the vidoe.... well done
as some else ask what is the ruff cost and you must be very skilled :)
Philly,
I got the kit below from Motion Control Products, and following a few PM's it seem's Fecn got his from there too (not sure if he got the same bundle though)
£220 ish + Vat
http://www.motioncontrolproducts.co.uk/ ... ducts_id=8
PM if you need help, or for a wiring diagram.
You can get cheaper stuff from the states, but I decided to stay within the UK in case I needed to send stuff back & get a quick turnaround.
The motor couplers (Lovejoy's) are easily sourced..I got mine from a local company who do motor rewinds, for about 12 quid each.
Limit/home micro-switches can be bought from Maplin, RS or most hobby electronic shops.
E-stop switch.. you may need to shop around for a good price. I bought a Crabtree model from a local wholesaler for about £20 IIRC.
608ZZ bearings came from Ebay, from a guy under the name of cinspider:
ebay link
You would need 30 bearings for the build...4 for each runner, making 8 for each of the 3 axes, plus 2 for each of the 3 leadscrews.
The rest of the materials? Aluminium angle, MDF, M8X1.25 threaded rod, nuts & bolts from wherever you wish. Mine all came from B&Q.
Regards,
Mick.
This is awesome, I never knew CNCs could be made at home! I thought they were way too complex for the average woodworker to build, will maybe give it a go in a few years.... Like the sounds though. :wink:
..and here:
Regards,
Mick.
Hey Mick...
So, since you have quite a bit of time on the machine, can you give me some feedback on what improvements you have made, what worked well, and what didn't work so well. I would like to add comments, or revise the text on the website so I can guide my visitors using the experience from a successful builder. Also, how much time did it take you to build. I posted a humorous sign at the Maker Faire that stated the time it takes to build: single - two weekends, married - 4 weekends, with kids - 8 weekends.
Very nice job on the machine! It's funny that most of the builders of my machine have completely surpassed me with their level of production. However, I think I may be focusing more time on the website and not on my own finishing touches.
I would love to get photos and your comments to post on the buildyourcnc site. Thanks!
Philly":kt01hvk5 said:
Patrick
You've been caught by our "spamulator" - once you have a few posts under your belt you'll be o.k.
Here is your link....
http://buildyourcnc.com/default.aspx
Must admit - I really fancy making one. What kind of money are we talking about for the motors, etc?
Philly :D
Thanks Philly... I love this site! When I get some more time, I can't wait to delve into this forum deeper.
herdsman":xwd6an1f said:
Hi Patrick,
Paul
Hey Paul,
Check out the videos at the link provided by Philly and feel free to comment, suggest and question. I love responding to questions and helping individuals make that first step to the fascination of fabrication and automation.
motownmartin":1dy1dre3 said:
I try and watch these videos and my PC freezes, so I am sorry I can't pass any comment :(
Hmmm... I'm porting the videos one by one to Youtube... It's a slow process, but keep an eye out for the videos there. You can also try from Metacafe. Maybe you need to upgrade your flash plug in, or try another browser. I have found that Firefox is pretty robust and resilient.
