tekno.mage
Hi there,
This is my first attempt at posting pictures here, so let's hope it works.
The following are pictures of my first attempts at bowl turning, shown in the order they were turned (during the last month.) All but the elm one were made from wood discovered in the firewood pile. They are all finished with two coats of chestnut woodwax.
First, a small spalted bowl - not sure what the wood is. The wood is pretty but the shape is not so good! Size is about 5" x 2".
Next, a larger one in very spalted (rotten) sycamore. Size is 6.5" x 3.5".
This is a tiny bowl from yew branch wood, size about 2.5" x 1.25". Whilst turning it I found there was a split in the bottom, repaired with superglue.
Ash dish, 7" x 2".
Spalted Oak bowl, 4.5" x 2.75"
Spalted Birch, 4" x 2"
Technical copy-turning challenge to test the Chestnut rainbow range of woodstains. All made of ash, the large black one is 6" x 1.5" and the seven small ones are 3" x 1.5" The seven small bowls are similar to the casual glance, but not as identical as I'd hoped.
Large spalted sycamore bowl. 8" x 3"
Holly dish. 4.5" x 3". Turned green so it's gone a bit oval.
Elm bowl, from a bought blank. 6" x 3".
Finally, a bowl from sycamore crotch wood, about 7" x 3". Unlike the spalted sycamore it was very, very hard & took a lovely finish straight from the tool, so required very little sanding (except for where I had to superglue a crack around a knot. ('')
Your comments on these would be greatly appreciated.
tekno.mage
Ash dish, 7" x 2".
tekno.mage
