Thanks Mark,its made up of uprights leftover from my staircase(not sure of the correct name for them
) I had a local shop plane them down for me(no P/T yet) to try and get a slight warp out,which worked well.I bought a nobex mitre saw specially(a fine saw IMO which I'm very pleased with) it cut the mitres very well with great accruacy.
I cut a groove out of all sides on the TS,thankfully the width of the blade was bang-on for the thickness of the glass(2.5mm preservation clear glass)Then cut a rebate out of the back to take the mount board and backer board.
I glued and brad re-inforced the bottom mitres and set the whole frame in a €10 stanley stramp clamp which was ideal for the job. Once dry I slipped the glass in and glued and pinned the top rail? I was a liitle worried I might of broke the glass at this point but it was fine.
Prior to assembly I'd sanded and sanded and sanded,painted,sanded.............Because of the construction method I chose(not ideal now that I've finshed)it meant I had to touch up the top mitres with paint once made up.Up on the wall its not noticable :wink:
I'm looking forward to making another one now,I'll have much more confidence and certainley learn from this one!!
I used conservation glass,preservation mount board and preservation barrier behind 6mm hardboard.The job of sourcing this specialist stuff was a real pain(only one supplier of the glass in Ireland!!!!) once found I had to overcome them only supplying to the "trade" and in large volumes.
I've several bits of art and prints which demand framing to preservation standards so It'll all be used eventually :lol:
