derekthedrill
- Joined
- 24 Oct 2007
- Messages
- 6
- Reaction score
- 0
Absolute beginner here, so go gentle please.
Up to now I have always used brutish mechanical fixings of one sort or another. I feel that it is time to start learning some more pleasing techniques.
I am building a small platform, raised from the ground, with two posts at one end, the other attached to a ledger. I need to join the posts to a beam. This beam with carry joists.
I hope that makes sense.
I think that a mortice and tenon joint would be good for the joint between the posts and the beam. Strong and attractive.
All the guides I have come across, assume that the timber involved in the m&t joint is relatively small. Smaller than mine:
beam is 160x90mm
posts are 100x100mm
My understanding is that the thickness of the tenon should be around one third of the thickness of the beam. This makes for huge tenon. Chisels don't come that big do they? And what a force would be necessary to make that chisel cut! Even a double tenon would make for tenons of about
40mm wouldn't it?
What is the solution? Doubtless I am barking up the wrong tree here. Please, direct me to the right one. My throat is getting hoarse.
derek
beam is 160x90mm
posts are 100x100mm
40mm wouldn't it?
derek
