Kalimna
- Joined
- 18 Nov 2009
- Messages
- 1,275
- Reaction score
- 2
Greetings folks,
Here are some photo's of a couple of boxes I completed this week. My first attempts at cutting mitres (hand mitre saw and shooting board) and making a box, so design wise, as basic as it gets.
Smaller box is some Scottish elm with a ?mahogany (wood came from an old table my mums' dad made - and he died before I was around, so don;t know exactly what it is) lid insert and camphor laurel inner-box-insert (don;t know if it has a 'proper' name or not), and the second one is much the same only bigger and purpleheart/scottish laburnum.
Upon neither did I attempt fitting a hinge, so the lids are loose, though reasonably snug fitting (the larger box's lid even fits if turned 180 degrees - Im quite chuffed with that). The lid and base grooves were cut using a veritas plough plane (liked using it a lot), the lid insert bevels with a block plane and then sanded over in the case of the smaller box.
Both sanded to 400, given 4 coats chestnut hard wax oil and then a coat of microcrystaline wax.
Overall, Im happy with them - the mitres came out better than I had planned (though you may notice the 'design adjustment' to hide slightly ill-fitting external edges - all stringing, walnut or maple, made in garage), particularly on the purpleheart box - the corners of the stringing were a bit finickity with the bevel 45 degree bevel on two edges.
However - I managed to cut the base groove a little too close to the base on the larger box which wasnt ideal with brittle purpleheart which then chipped and doesnt support the base as much as I would have liked, and also the maple edging didnt llike being planed at all, due to some nice ripple. I also didnt get around to adding strengthening splines, eejit that I am.
So, have a look, and any comments or criticisms and suggestions for improvement/next box project are very welcome (however good or bad!)
Cheers,
Adam
Purpleheart and laburnum
Elm and ?mahoga-wotsit
Cheers,
Adam
