Hi folks!
I recently picked up a Multico A1 which has these grease fittings.
When I took one of the wheels off, the grease was completely dried out, but there is no play, so I don't think any metal has worn out.
Will any type of grease gun work with these fittings? I saw that there are some with locking jaws, but not sure if those are only for ball type fittings.
For grease itself, I was thinking about something like this: https://www.amazon.co.uk/gp/product/B007WR38TY
Or this, which I think is the same thing, but in a cartridge: https://www.amazon.co.uk/gp/product/B002E2LR72
It says it's good for bearings, would that work?
The motor is an old Brook unit, and it has two grease fittings as well:
Should I pump some in there as well, or does the motor need a different type of grease? I emailed Brook, but it seems like it's a big holding company, I'm not sure if they will have advice for older units.
I think with motors, less is safer than too much when it comes to grease, and in a different thread on the forum I saw some advice to just open it up and grease by hand if needed.
I might give that a go if it's the safer option.
