Doug B
Shy Tot
I recently bought some cheap Imperial blades for my Bosch multi tool in an effort to save money but as usual you get what you pay for & they were sh1te.
Still not wanting to pay top dollar I thought I`d have a play at making my own
So this morning at Screwfix I bought an Irwin japanese type saw for £15, a fiver less than 1 multi tool blade, this i marked out to the size of blades i wanted.
Using an off cut of steel as a fence the sections were cut up with a 1mm grinding disc & cleaned up on the linisher.
Next old blades were parted from there collars at the miller using a carbide bit to drill out the spot welds, the same could be done on a slow running pillar drill & a re-ground carbide masonary bit.
Holding the new blade & collar in long nosed mole grips which in turn were held in the vice the 2 pieces were silver soldered together, taking care not to let too much heat travel down to the teeth.
5 finished blades (one on the multi tool) & 2 spare ready for collars.
I`m not saying they are pretty, but they work a treat, I`ve tried them on some pine & Oak with very good results.
Hope it`s of use to someone.
Cheers.
Cheers.
