mickthetree
Hey all
I've got a sip 1/2" morticer which I've been considering getting rid of as I dont use it much. Thought I should give it a good workout before making a decision and I've been moderately impressed.
Cuts through oak and beech and pine fairly well.
Main trouble is the bits. They cut pretty neat edges, but the drill bit marks the outside walls of the mortice. I dont want to snug the drill up any tighter into the chisel as it would be too tight and heat up and it seems to bind up with wood and stall the motor.
So how do you set the drill bit? Should it be tight but use a lubricant? or loose or is there a sweet spot you have to find?
These are cheap bits I believe, but still they can produce some reasonable results.
Could do with raising the table on it also as the chisel stops quite short.
