Grahamshed
Still debating about the woodburner but Ii am now wondering about burning stuff like MDF and chiboard and especially the sawdust from them. Anyone with experience ? Is it a problem ?
Jacob":1onrmvcg said:Sawdust will burn from the top. You can't put it on a hot fire or it will blow back. Instead you let it burn down , then fill it up and light it at the top.
Or if you choke the fire with sawdust it smoulders away for some time then suddenly goes woomf.heimlaga":2mdhfnnj said:A blow back is when you throw sawdust onto a fire and it almost explodes in the air above the fire.
Why not? In burns really well. I burn tons of both.... Chipboard should not be burned and MDF is questionable ....
Jacob":2xto6502 said:Or if you choke the fire with sawdust it smoulders away for some time then suddenly goes woomf.heimlaga":2xto6502 said:A blow back is when you throw sawdust onto a fire and it almost explodes in the air above the fire.Why not? In burns really well. I burn tons of both.... Chipboard should not be burned and MDF is questionable ....
Jacob":c03xnojq said:Why not? In burns really well. I burn tons of both.... Chipboard should not be burned and MDF is questionable ....
If it's toxic it might just as well go up my chimney as lie around being toxic as landfill.newt":1b8wkoip said:Jacob":1b8wkoip said:Or if you choke the fire with sawdust it smoulders away for some time then suddenly goes woomf.heimlaga":1b8wkoip said:A blow back is when you throw sawdust onto a fire and it almost explodes in the air above the fire.Why not? In burns really well. I burn tons of both.... Chipboard should not be burned and MDF is questionable ....
Jacob, you may have missed one of the points, of course it burns well tons in your case, but what about the impact of the products of combustion on other folk, thought you were the caring type.
katellwood":3pu47nf1 said:I would ask how waste disposal companies and Local Authorities get rid of Chipboard and MDF. as most LA's now incinerate most of their waste surely it just goes straight in the fire, or am I wrong
Jacob":2urhrnd6 said:I burn mdf, chipboard, no prob. They burn really well like phurnacite. And loadsa softwood including painted stuff. Any old rubbish, cardboard, some plastic, etc.
I don't burn plastic from choice but the occasional few bits get thrown in, tbh.Sheffield Tony":2eemzfi3 said:Jacob":2eemzfi3 said:I burn mdf, chipboard, no prob. They burn really well like phurnacite. And loadsa softwood including painted stuff. Any old rubbish, cardboard, some plastic, etc.
I'm glad I don't live downwind of your shop. Burning plastic is not a great idea; burning chlorinated plastic like PVC with paper/wood is an especially bad idea unless the flue gasses are kept hot enough (and a normal woodstove is not) to prevent the release of dioxins.
