Doug B
Shy Tot
I recently bought a Hammer 4400 bandsaw of a fellow forumite it came with the factory fit mobile base but due to space restrictions moving it with the jockey wheel lever was a pain.
l’ve previously made with the help of a mate four mobile bases for my machines, all to the same design made from angle iron & with four locking casters, so this afternoon I popped over to his to make one for the Hammer & while there took a few photos.
First order of the day was to cut mitres on some recycled angle iron to form a frame.
A V shape was ground on the mating surfaces that were to be welded then these were joined together.
After cleaning up the welds the casters were masked up & these to were welded to the underside of the frame.
A sanding of the frame & clean down with thinners was followed with a couple of coats of primer.
when a coat of Satin black top coat was dry it was back to my workshop & just a case of popping the bandsaw into the base.
The four locking casters prevent any movement when locked off but when unlocked I can move it in any direction, also what I really like with this design is there’s no parts sticking out to create a trip hazard.
