I bought this little lathe as I am building a wooden clock and needed something to turn a few small pieces. It has done a great job, look at the pictures, and works really well. Having been given a bigger lathe for Christmas I no longer need this little fellah, so it has to go.
Although the chuck only accommodates a 6mm shaft, I got round this by drilling larger pieces with a 6mm hole and mounting them on a 6mm spindle (threaded bar). The larger pieces in the photograph are actually 30mm in diameter and it handled them easily.
I have added a small piece of wood on the tool rest for when I turned the longer pieces, which is only held on by a couple of screws.
It has a fully (removable) live centre in the tailstock.
There are three mandrels for turning round bead objects and a 6mm driver for the chuck for turning larger diameters without having to clamp them. Oh and I'll throw in a set of small wood turning tools as well!
Specifications
Power: 96W
Voltage: 24VDC
Rev: 4000-7200 rev / min, 7 speed regulation
Maximum clamping length: 130mm.
Clamp range: 0.6-6mm
Postage will be £4 to anywhere in the UK.
ALL YOURS FOR JUST £35.
Specifications
Power: 96W
Voltage: 24VDC
