Hudson Carpentry
How about you drill 19mm Holes and turn some 19mm dogs thats square at the top but round to fit in the hole then also have some 19mm 100% round. Best of both worlds.
On the same note if you had a row of square holes them half round half square turned dogs will also fit in the square holes if you make them to that size so you then also able to use round dogs in the square holes.
