RossJarvis
DO NOT BUY THIS!!!
I can't believe that Makita actually made this tool. Unfortunately I left too much time from purchasing to using it to send it back due to not being fit for purpose.
1, = Fence, is not straight and probably not square to surface. It bows into the middle, therefore the blade cannot be set square and trimming ends is impossible.
2, Laser, = Not in line with blade from factory and not trustworthy unless set by user. Due to fence issues fairly useless in all uses as it can never be set straight.
3, Table detente's, = When swivelling the table it "clicks" into preset angles. Unfortunately there is up to .5 degree wobble on each detente.
4, Motor intrusion, = Due to the motor, it is impossible to hold onto the workpiece on the left of the cut, there is a position for the work clamp on the left of the motor but it can't actually be used.
5, mounting points, = If all 4 mounting points are used, it is likely that the nut on the front right will stop the table swivelling all the way to the left.
6, Blade change, = It is tricky changing the blade, if a thicker blade is used it is almost impossible to fit, this machine seems to have no thought put into blade changing.
7, Depth of cut, = It was probably in the spec, but this can't cut anything thicker than 60mm.
8, Guard Issues, = The guard will catch on lots of work and is hard to release if using a human hand.
9, Dust Bag, = Very small and had a hole in it, therefore pointless. When connected to extraction a reasonable amount of dust is extracted, but not all,,,,,by any means,
10, worklight = The machine has a work light, If the working environment is poorly lit enough to use the work light, it is far too poorly lit to use this machine.
11, = Extension supports. On either side of the machine there are bent bar extension supports which are removable. These are not level with the work table and cannot be adjusted to meet table level.
The machine undoubtedly has other faults I have either forgotten or not met.
THIS MACHINE IS REALLY CREPE!! It is what I'd expect from a no name budget company, not Makita. I own and use several Makita tools which are to type, primitive but well suited to their tasks, powerful and very well made. THIS IS NOT!
EVERY TIME I USE THIS TOOL I REGRET BUYING IT!!!
