Tks for that - yes, they do look similar. I don't think heavy duty is a necessity for MFT workCan't help you with exactly what you're asking, but for what it's worth I have several of the Axminster quick lever clamps (these ones) as well as some of the Bessey equivalents. The Bessey ones are definitely heavier duty, but the clamping action of the Axminster ones is lovely, they clamp securely and they're the ones I reach for most often of all my clamps.
I imagine the guide rail clamps are exactly the same but with a different foot to go into the track.
They are indeed. You can find pairs for about £64 inc. VAT on the bay. Epic Tools I think was the seller I got mine from.https://www.its.co.uk/pd/GTR16S6H-B...KVwKnf_XKINGjuiw-Z6SMtDPO0OB4eA8aAv02EALw_wcB
are these the bessey ones?
Agree about more general use.I was trying to fathom out what all the fuss was with the MFT bench and dogs and could see a few uses but with several limitations but in the process I came across these clamps and they are really versatile, will make making jigs and fixtures very easy and I could easily see the potential. You could add some dogs to provide an extra level of squareness and I am already making some new fixtures for my Woodrat. Look at the Matchfit site and see what you think MATCHFIT Woodworking Jig and Fixture System | #1 Best-Seller in Jigs and Fixtures
Rutlands also have packs of 4 for £70 (Forged Quick Lever Guide Rail Clamps | Next Day Delivery)... which is perhaps too cheap. They're longer at 300mm vs 160 for the Bessey / Axi / Festool ones though; more capacity but also more cumbersome.
They're the version I havehttps://www.its.co.uk/pd/GTR16S6H-B...KVwKnf_XKINGjuiw-Z6SMtDPO0OB4eA8aAv02EALw_wcB
They work well with mine. I incorpporated it into a Timothy Wilmotts design that has t-tracks on both long sides and one short side so I can either clamp the workpiece flat to the table top, eg for cutting to size with a tracksaw or upright against the side frame e.g for cutting dovetails etcAnd the Bessey ones, are they a good fit for MFT tops please?
They have a very good name.
They fit very well indeed. There's very little between them and the Axminster ones. I have a niggling feeling in the back of my mind the Axi ones were made by Bessey but to an older design. They vary slightly from the current Bessey ones but functionally they're very close; both better than the Festool ones IMHO.And the Bessey ones, are they a good fit for MFT tops please?
From a thread on the Festool user group, there seems to be a suspicion that all 3 were from a common source, Axminster, Festool and Bessey - which would make sense.They fit very well indeed. There's very little between them and the Axminster ones. I have a niggling feeling in the back of my mind the Axi ones were made by Bessey but to an older design. They vary slightly from the current Bessey ones but functionally they're very close; both better than the Festool ones IMHO.
Worth knowing - though I've been using 'ordinary' screw clamps for years without noting this. Perhaps the vibration of the saw?IMHO, the screw versions are a waste of money as they loosen themselves when you're not watching (due to vibration mostly).
