segovia
MFT Workbench MKII, MKI was to see if I needed an MFT bench, the answer was yes. The mid-compartment on the right was supposed to be a sacrificial surface when using the circular saw. However, I thought it would be better to use it for storage. I removed a draw from the cabinet and everything that was in that has gone into the new compartment. The bit on the end is a general tidy-all to get tools I am working with off the work surface. Still some work to do, I may drop it by 80mm although he current height isn't that bad to work from. I'll reinforce the base and add some drawers or maybe shelving and a door or two, or a combination of the two. The top is an eBay item and I bought the Trend Jig to make the side MFT panel. it aligns with the top holes with a bit of wiggling, I have not got a permanent fix on the top, I am unlikely to use the top and bottom holes together anyway. Side is more of a secondary vice
