Sporky McGuffin
Light entertainer
Arfernoon all - thought this might be helpful for anyone else who wishes to escape the tyranny of Imperial T-Track and use good, honest, scientific metric fixings. I hope this is helpful, and interested to hear of any other solutions people have found that avoid buying weird Imperial stuff.
On the K2 CNC machine bed (meant to take 1/4-20 Imperial fixings) I've been using either M6 square nuts or M4 drop-in T-nuts, each with a bit of studding and a little thumb nut. These can exert astounding levels of pressure.
On the Incra stuff the T-slots are also meant to take 1/4-20 (I think) but are a bit wider inside, so the M6 square nuts don't work quite as well - they can still rotate until they're tightened a bit. The M4 drop-in T-nuts work perfectly though, and the advantage of them is (if the name isn't enough of a clue) that you can insert them anywhere along the track and they twist into a locking position. For anyone wondering what I'm talking about:
Here are the M4 bits on their own:
Here's a blue clamp with the M6 bits, and a red clamp with the M4 bits
And here's both on an Incra right angle jig (these aren't the clamps I'd use on this jig, just to illustrate that they do work):
Also useful for attaching sacrificial fences, temporary stop-blocks, and so on.
![20220104_193708.jpg 20220104_193708.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/106/106972-20220104-193708.jpg)
![20220104_193409.jpg 20220104_193409.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/106/106974-20220104-193409.jpg)
![20220104_193601.jpg 20220104_193601.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/106/106976-20220104-193601.jpg)
