Another question about bandsaws. I have an SIP 10" and want to be able to cut metal, mostly aluminium but some thin (2mm) steel.
New thread started.
To add to the posts above, most of which are spot on, you can also look at a LONG sticky thread about cutting metals of various types and thicknesses which is right at the top of the General Metalworking Section.
It lists just about all the affordable (to the hobbyist) metal-cutting "tools and gadgets" from hand tools like hack saws up to band saws designed specifically for cutting metal (they're a MUCH different animal to band saws for cutting wood, for the reasons - and many others - outlined by other posters above).
There are MANY tools much more suited to the occasional cutting of metals - hack saw (NOT hard work if you know what you're doing and use the right blade/s, see article); angle grinder with cut off disc; coping/jewellers/fret saw with suitable blade/s (for thin sheet); "nibbler" attachment for hand-held electric drill (also mainly for thin sheet); "tin snips" (various types - also mainly for thin sheet but often distorts the edge, again see article above); and if available, the "Goscut" tool (again see that sticky).
It's your money and choice of course, but personally, unless you are going to be cutting metals REGULARLY, and in relatively large quantities and of wide variety of types & thicknesses, I consider a metal cutting band saw to be both a waste of money and of workshop space. In fact I do not have one, despite doing quite a bit of metal bashing in my shop.
HTH
Edit for P.S.
Also agree with a poster above who suggests a jig saw. Can work very well, but again, needs careful set up AND the right blade/s (sorry, see that sticky article again)!
Edit for a further P.S.
(Sorry Grandad 455, I really am getting forgetful in my old age)!
Especially bearing in mind your mention of cutting 2 mm thick sheet steel, please don't forget the "minimum of 3 teeth always in contact with the job throughout the cut" rule. (Sorry if I'm teaching "grandma to suck eggs")!
That rule especially applies with 2 mm metal (and thinner - any metal BTW - especially if you do not want any distortion/curling along the cut edge/s).
So IF you have one, another ideal tool for that job is a powered scroll saw (with the right blade/s, as ever). But no problem if you don't have a scroll saw, a hand-powered "fret/jewellers/coping saw" will do the job easily, but once again, you need the right blade! As we're talking about a thickness of only 2 mm, that clearly means a VERY fine-toothed blade if we're to obey the above (vital IME) "3 teeth rule".
But that's NO problem because over on the Scroll Sawing Section you'll find another "sticky" (it's also long, sorry) in which you'll find a lot of details on who makes what blades and where to buy them. That article is of course mainly aimed at wood working, but both powered scroll saws and "jewellers/etc" hand saws use the same blades for cutting thin sheet metal, and both tools are regularly used for that purpose by the professionals.
BTW, you need have no fears about time/difficulty taken to cut by hand if you don't have a scroll saw. The above sticky includes downloadable tables from a couple of manufacturers listing blades designed especially for cutting sheet metals of all types, including sheet steel. And with the right blade, even using "only" a hand-powered jewellers/etc saw, the job really does become a "hot knife-butter" act!
Done it myself loads of times, both manually and with the scroll saw.
Again, HTH
