Is that 19mm across the top of the track, or across the the bottom (which I assume is wider)?I bought one of these over a year ago.
I'm quite pleased with it.
I'm having difficulty sourcing T track nuts to fit the groove. it's 19mm wide, all I can find so far is 23mm .
Across the bottom.Is that 19mm across the top of the track, or across the the bottom (which I assume is wider)?
I've made T bolts from coach bolts, just file or grind two opposing flats to suit track. T-track nuts are easy enough to make, or modifying slightly bigger ones, even square nuts of appropriate size.No one?
Yes I did that,I've made T bolts from coach bolts, just file or grind two opposing flats to suit track. T-track nuts are easy enough to make, or modifying slightly bigger ones, even square nuts of appropriate size.
Is there more than one?Do tell which one Artie as others may have a similar need
