18mm is good, several options for making them shaker, proper panel and groove with stub tenons which is a lot more work but they do seem somehow stiffer, or “faker” with just pinned (or mitre
Mate and titebonded) on trim pieces..
at 5ft high the worry is cupping or bowing during painting, particularly if you are spraying.
This generally happens when one side gets wetted and dries, so a couple of ways to mitigate.
Hanging the door vertically for painting is great, and allows you to paint the whole thing in one go, which makes this as small of a problem as possible. It is extra effort but is always worth it.
Pre empting that they are mdf and may bow at some point, you can also let in door straighteners..
Or easiest and likely worst advice is just put more hinges than you think you need, which will at least do something to pull the door into a straight line on the carcasse side..
As always overlay doors are easier than inset
Ta
