Matilda Bow Saw.
swagman
13 Feb 2008
Victoria, Australia
Hi all. Attached are photo's of a bow saw I recently completed. It has a 12" blade fitted.
The concept behind my design was to generate enough tension for the bow saw blade, but create this tension within the lower half of the frame where it is ideally functional. This alleviates any need to overtension the upper frame such as is required on a traditional bow saw.
This lower tension is provided by an 0.040" saw steel band, bent within this lower frame, that creates significant "spring" outer pressure onto the blade.
The main role of the tightening cord is now to firm up the bow frame, locking the horizontal spreader to the 2 vertical arms.
Both handles slide into a brass bush, with the threaded rod allowing secure tightening to the frame.
In function, the bow saw works extremely well. I have called this design, the Matilda Bow Saw.
Regards; swagman.
Nice...but I can't see any advantage on this variation that will have significantly improved the original design, which lets face it, has been around for at least 2000 years.
This is a frame saw I did recently with a 6mm rod to tighten the whole gubbins up, which is a departure from the traditional cord tourniquet:
If it ain't broke, it don't need fixing :wink: - Rob
Ah but Rob you've done a deviation form the original design with your screwed rod and wing nut. Personally I find it detracts and would rather see the original tightening method.
If it ain't broke fix it till it is :wink:
Ah...but you see Waka, the ancient Romans wouldn't have had a 6mm threaded rod...both methods though work equally as well. I suspect that the original model would have used twisted sinew and may have been a direct 'lift' from the military war machines of the time - Rob
Stewie and Rob, both are very well thought ideas. 8)
Well done to you both. :D
Hi, Chaps
Here is my curvey babe of a coping saw bowsaw and the things she does.
Nice work gents, I've been meaning to make one for quite a while.
Just one question, where do you get your blades? Would bits of bandsaw blade do?
Aled
Hi,
**** tools do them http://www.****.biz/****/category/dickc ... detail.jsf
Or you can use bandsaw blade.
Rob,
I think that is still basically a bow saw. IIRC, frame saws have the blade in the centre of a wooden frame and are used only for ripping down boards that are narrow enough to fit within the frame outers.
Like this one:-
They would if they went to see Hengis Pod :lol:
Hi Rob. If you still use a horse and cart for transport, still use a bow & arrow to kill your food, and also refuse to use any other means of modern idea's , I would consider you are a seriously believer in the statement " if it ain't broke, it don't need fixing". :lol:
Seriously.If you can make an improvement to the original design, and it can help others who will also benefit from its use, its got to be worth doing.
All the best; Swagman.
