triker64":cwrnilp2 said:Hi I have a Mancuna hand pillar drill and would like to change the chuck for a key tightened one, any ideas if this can be done?
kesterlester":1z53b215 said:triker64":1z53b215 said:Hi I have a Mancuna hand pillar drill and would like to change the chuck for a key tightened one, any ideas if this can be done?
Did you change the chuck? I just realised that my Mancuna hand drill chuck is damaged (two of three broken springs) and I'd like to replace it with an original.
If you are no longer using yours I'd by it from you for the right price .....
Bod":1a7nw7k6 said:The white arrow points to the speed changing device on mine.
There is a possibility, that there is quite a variation in these drills, all using the "A2X" base castings.
Mine is a two speed, and I have seen a single speed with the same "A2X" base.
A photo of yours would be interesting.
Bod.
Bod":2kbh7hjo said:kesterlester":2kbh7hjo said:triker64":2kbh7hjo said:Hi I have a Mancuna hand pillar drill and would like to change the chuck for a key tightened one, any ideas if this can be done?
It's not difficult to replace the springs, just use 3 identical, as close to the one you have undamaged, for length and strength.
Bod
No mine appears to be a single speed but when drilling if you just turn the handle and leave the feed wheel alone it does self feed albeit slowlyis your drill a one or two speed? I have a 2 speed, but can't quite work out how to change the setting!
No not cha fed it yet decided to live with it for a while and see how it goes.Did you change the chuck? I just realised that my Mancuna hand drill chuck is damaged (two of three broken springs) and I'd like to replace it with an original.
No not changed it yet decided to live with it for a while and see how it goes.
