Man cave
Cretin
23 Nov 2016
Monaghan / Ireland
One side of the man cave set up for clean work.
    65.7 KB
All doors and drawers flush and no handles, a 25mm shadow gap is left above the doors for a clean flush finish.
    161.1 KB
Ah i see, looks nice and tidy. time to mess it up and get a project underway :)
All units white 18mm MFC with a 2mm grey PVC edging. Doors, drawers and worktop are a brushed steel effect MFC 18mm with a 2mm black PVC edge all round , the vinyl decals were added to give a workshop effect
    149.6 KB
    162.8 KB
Thanks no skills, I have access to a hand held festool band edger it's a great job. It's a lot slower than a big band edger but you can edge internal and external curves with it
Other side has a fold away spray booth, because I was fed up covering up everything when spraying. And wooden work bench I will get you pics!
I didn't have this set up when I sprayed the camper bed and I was a full day cleaning up over spray, so I can fold out the walls now and it's a separate room but still have the option of the full shed
    171.4 KB
Sure was Steve, there was a few problems to overcome. Biggest problem was floor being 40mm off level and I didn't want a gap under the wall because my extractor might suck in dust while spraying
White boards fitted, units filled.
    59.2 KB
    58.2 KB
    74.2 KB
    62.8 KB
    47.8 KB
    60 KB
