AFFF
I have a Makita RP2301FCX 1/2" plunge router which I'm going to mount in a router table. The manual says that its height can be adjusted from above the table by inserting a M6 135mm bolt through the table into a threaded hole in the plunge base and through to a threaded hole on the side of the router. Problem is the head of the bolt is a Phillips head and the bolt is not made from the best steel. I can see the head getting worn very quickly with cam-out. Plus the bolt is only partially threaded so full height adjustment is not possible. The manual recommends manually adjusting the tool height from under the table and using the bolt for fine adjustment with a screwdriver. A "half arsed" solution!
So, I thought. Why not get a fully threaded 135mm M6 stainless steel bolt with a cap head (allen key or torx) to provide a proper above the table adjustment system. The head needs to be <= 8mm in height and <=10mm dia.
I have searched the web high and low for one of these..... Can't find any. Does anybody have an idea where I could get one? I have put a request with one online supplier who offers a bespoke manufacturing service but I suspect the price might be prohibitive for a one off. Any ideas?
