I`m after a router for general use & particularly for kitchen worktop fitting. This router has some very good reviews & seems to be on offer for a low price for a Makita. The query is whether the rather unusual design where the body rises & falls on a giant thread which wraps around the body would allow cutting a 40mm worktop easily with a few passes? It seem the height variation is just 30mm so I thought if the cutter chosen protrudes beneath the sole plate by 10mm to start with then you would dial your way down with successive cuts. If that`s possible or you have one & know it`s strengths & weaknesses relative to an `ordinary ` plunge router it would be great if you could advise. Many thanks.
