Making dowels
peter-harrison
25 Jan 2018
Cambridge
Hi everyone, I have a job coming up which involves making about 36m of 50mm diameter walnut dowelling. I am thinking of making it on the spindle using a cutter set that does a 1/4 radius of 25mm. Has anyone else done this kind of thing and if so, any tips?
Thanks for looking!
Thanks for looking!
Plane 50mm square lengths.
Power feed essential and a 1/2 round cutter for two passes.
I made a jig ( copied from Youtube ) It uses an electric drill rotating a blank that goes through a jig over a router cutter. It works well but my initial jig was just bodged up to try the method and needs re making as it wasn't sturdy enough.
Thanks for looking!
Please tell us more... 36m of 50mm walnut dowel!!!??? what are you making? sorry i cant help with the manufacture...
I dont know how long you need per piece but if you have a lathe make a frame over the bed with a slot along it to carry a router and follower rotate square wood slowly and pass router along the length you can control depth of cut manually untill you reach your desired size or a little above and finish sand
Without knowing more about what you are making, my first reaction would be to look at the design and see if it could be done differently without compromising the finished products aesthetics or structural integrity.
If you make these with multiple passes on the router table you may end up in the situation where there is to little support on the outfeed side, ie it is 75% round!
Are you talking about a spindle moulder? Most of the answers are not, I might have missed the point!
But 4 passes on a router table should be OK as long as everything is precise, solid, bed/fences long enough, held with feather-boards both in and down etc. You might have to do a bit of finishing sanding perhaps. A spindle moulder + power feed is much more precise.
Yeah, Mr. Maskery has a tutorial on YouTube on this method as well.
Hi all, thanks for the responses. I am planning to use a spindle moulder with a power feed. I’ve used a dowel plate many times but I think driving multiple 2.4 m lengths of 50x50mm through one would lead to my early demise!!
I was really looking to see if anyone had done something similar and had any specific tips to share
It’s for some posh headphone stands. There’s a wooden base, a metal bar and the cylinder on top which is what the headphones rest on. I’m making 500 of them. It isn’t going to be the most interesting thing I’ve ever done!!
something you might find helpful: - brilliant, you would be VERY hard pressed to find a better solution, I certainly have not and Ive seen all sorts of jigs for dowel making.
Looks interesting!
I reckon a spindle moulder would be faster and neater though - but everything would have to be spot on, firmly held and very solid. And it's how they do it commercially - if done badly you can see where the two passes haven't quite met perfectly.
That is very clever and would be perfect if it wasn't for the level of finish required and the quantity. I had a job a few years ago, making viaduct kits for Brio trainsets, and this has made me very wary of large numbers. What might seem a bit trivial, like taking 10 or 20 minutes to fine sand a 2.4m x 50mm x 50mm dowel, becomes a very big deal when it's 30 of them!
My mate does miles of the stuff on his Weinig moulder but I imagine the setup would be a a bit more challenging on a conventional spindle, especially if you wanted to power feed. I might have a play tonight.
