dedee
I need to make some architrave like this.
I am not too concerned about the rounding at the narrow end. A straight 3-4mm edge would be fine and I expect easier to do. Dimensions approx 15mm high x 40mm deep
All I can buy over here are the fancy multiple ogee designs which do not meet with the approval of the boss.
I have a router table (it's the one that the late Barry Burgess made) with the Triton TRB001 router. Unfortunately the move to France got in the way of me ever having a chance to use the table and router so this is very much a newbie project for me.
Is this a straight forward job for a novice? What type of router cutter (or cutters) do I need? Is it easier to do this type of job with or without a bearing cutter?
If I make a success of this I may well be making new architraves for at least 5 door frames (both sides) so I do not mind buying a quality long lasting cutter.
At the moment all that covers the cap between the wall and the door frame is D section moulding, which is very typical over here but looks awful when either tiled or papered up to.
Andy
Andy
