RogerS
Doug71":13vbsn22 said:I know you shouldn't and I wouldn't advise people to do it but I often make climb cuts with the router. I find if you are for example doing an arch which is joined in segments each segment is half with the grain and half against the grain. I sometimes find it easier and less likely to chip if I take small climb cuts moving with the grain then finish with a really fine cut against the grain.
I only do this with the hand held router and work piece clamped securely, wouldn't do it on a router table as it can pull your fingers in if it gets away from you.
I do have a small power feeder for use with my router. Climb cuts are a doddle then but only on straight bits of wood ! And just thinking about it, I guess I might have been able to use the feeder if I was very clever orienting the wood around in a curved path..a damn big 'IF" !
