Chris_belgium
- Joined
- 7 May 2006
- Messages
- 272
- Reaction score
- 0
Caution tool gloat
Gave myself an early christmas present and bought one of these bosch Fixed base/plunge base routers! Kinda pricey but got a good deal and I really like bosch stuff.
But it left my wallet empty so no cash left to make a router table! I managed to make a low budget (read no budget ) table based on info I found in this thread https://www.ukworkshop.co.uk/forums/viewtopic.php?t=24219&highlight=router+table+fence So thank you Mr. Maskery!
It looks nothing like all the beatifull Norm style router tables usually on this forum, but it works for me for now.
Base is a 18mm mfc board glued to a 30mm mdf board. To my suprise this 48mm thick supposedly stable board had a bow to it! The middle was 1,5mm lower than the sides. That's the main reason for the heavy metal framework underneath rather than a nice wooden frame. An added advantage for me was that I can mount the table in my work bench, and when not need, hang it high and dry somewhere on the wall.
I didn't use a router mounting plate but just screwed the fixed base part of the router directly underneath the mfc board. I can raise the collet to approx 5mm underneath the fence, so not much cutter length loss. The fixed base is also fitted with a through the table heigth adjuster wich makes things a bit easier. The motor can be taken out of the fixed base fast and easy wich makes changing the cutter easy.
Only major problem I ran into is that I couldn't get the wooden sliding pieces to fit perfect I tried three times and failed everytime Last attempt still left me with about 0,5mm play from one corner of the fence to the other. This is not a major problems since I know this and just line op the fence with a 90°square. Is there an easy trick to get these pieces perfect or is it just impossible with the mfc boards? (sliding piece itself is hardwood)
First test piece, 'planed' it with the table using a 2mm metal bar as secondary fence. Turned out rather well, even if I do say so myself.
Altough not of the same level of craftsmanship as most of the work I see on this site, I had fun making this, it will work for me for the moment and I learned a lot from making it. Couldn't of done it without the search button on this forum, thanks for that!
