Hi,
Bit of an odd one this one.
I'm wanting to make a stand for various implements in the garden, drawers etc for cooking utensils and a cutout for a small Argos BBQ. The whole thing is probably going to be made from Sapele milled by myself. For the assembly I was thinking of milling my own 10MM thick tenons on the thicknesser for an optimal fit and cutting the mortises with a 10MM Festool upcut router bit then covering the lot with glue. One thing that's let's say, at the front of my mind is that I am thinking of the moisutre over the years getting into the gaps and expanding the whole thing leading to failure.
Am I better...
A) Going ahead and hoping that Jesus is on my side and the joints won't expand over time, assuming the Sapele won't expand and contract too much...
Or
B) Using loose tenons and drilling some hardwood dowels through both sides to stop the expansions and weakening over time. I have considered a Festool Domino with some hardwood sipo dowels but I am looking at more going down the router route as a Domino XL is out of my budget at the moment and the XL wouldn't get enough use to warrant me buying one. Hence wanting to go the plunge router way, as well as being able to make much wider tenons e.g. 50mm.
I aren't too keen on using screws as it just doesn't feel right to ram some screws or coach bolts through the outside on the nice sapele.
Appreciate any advice or any other methods of doing this.
Thanks,
Designer1
Am I better...
Or
Thanks,
Designer1
