Hi all
When designing a regular mortice and tenon joint the guidline is to always keep a minimum of 1/4" (6mm) of timber around the mortice.
Typically when building a table you'd have the mortices in the legs and the tenons on the rails. Does the same guidline apply to loose tenon joinery? So using the table example would you want your routed slot for the loose tenon at least 1/4" from the edge of the rail or can you go closer?
Seems to me that for loose tenons both componets in the joint have "mortices" and so should have 1/4" around the joints.
What do the experts thing??
Regards, Andrew
Regards, Andrew
