Orraloon
The trick with splitting eucalyptus is cut the logs short. About 10''. I had a slow combustion heater for about 20 years and cut all my own wood. I used a block splitter. That said some is so spirally and twisted in the grain that only the chainsaw will split it. I soon learned what not to bring home as some species of euc are not worth the effort. There are many hundreds of speciesYou could make a brick rocket burner outside, with a cavity to put in a few loose fire bricks. Heat them up, then use metal-work tongs to transfer them into a grate in the studio. Sauna-style. My question to you is how do you split eucalyptus? I took down a big limb from a blue gum and cut it into log lengths. My splitter won’t go into it, my large Fisk axe actually bounces off it, and wedges just break chunks off the wood. I'm going wait until it dries out to try again. How are you doing yours?
Regards
