woodbloke
I see from the Axminster site that the No9 is not shown with the 'hot dog' handle. Probably an extremely stupid question, but is it sold with the plane or does it have to be bought separately? - Rob
I recommend the same. If they are selling off old stock, you'll get the front side knob but not the hotdog; if you get a newer one, you'll get the hotdog with no knob (also, no tapped hole for a knob). On another forum there is a fellow who just sent his new #9 back for LN to tap a hole for a knob!Paul Chapman":15e8k7hz said:But I'd 'phone Axminster just to be sure.
What knob would that be? The stanley no 9 has a rosewoos knob fitted to an extention as the back of the plane. Later models have an tapped hole in both sides to fit the nickel plated hotdog handle.AHoman":1jg4zuqh said:On another forum there is a fellow who just sent his new #9 back for LN to tap a hole for a knob!
Tony":23qdpj6w said:I made a couple of hotdog handles (one for Philly) in an hour, and like to use both types at different times.
chisel":1s773hub said:I recently acquired a rather nice No9
If it's a Stanley no 9 without a hotdog handle you have a very early and valuble block plane. Either don't do anything with it or use it by holding the casting directly. (the very first batch of the no 9 from Leonard Bailey himself did not have any handle nor any knob) If the hotdog handle is just missing get a reproduction or antique nickel plated handle or make your own wooden one (any dense wood will do). You can identify if the handles are missing because of two threaded holes at both sides. The handle slides over the casting and is secured with a screw. A pressure fit handle will work but only when its the full length of the inside of the plane.chisel":1i763pkl said:I recently acquired a rather nice No9 ... so was going to resort to making my own when I've figured out how !Tony":1i763pkl said:I made a couple of hotdog handles (one for Philly) in an hour, and like to use both types at different times.
The LN hotdog is also screwed on normally. The screw is fitted from the inside up to the wall of the side of the plane (or would that be the top/bottom with the blade through the side?)chisel":3sb3c6uj said:Hi Christian, nothing old and rare I'm afraid, just a recent day LN No9, but very nice all the same ! Will see if I can get time at the weekend to sort out a hotdog and look at whether I can make it full length as you suggest.
chisel":2bllkxf1 said:Hi Tony,
When you made the hotdogs did you just make them a tight friction fit on the side of the plane, or did you use any other mechanical means of fastening ?
Cheers, Paul.
tnimble":38ushhcj said:What knob would that be? [...]
The LN (as per pictures on their site) has both knob and handle in cherry.
My point was that the versions of LN which did had the front knob are the odd ones. Leonard intended the plane to be held by the casting itself. No knobs at all.AHoman":1m2w6pu8 said:I'm not sure which site you are viewing. On the LN site, you can see that the knob on the side of the front of the plane is now gone. The hotdog, which used to be optional, is now included as standard. If an online store is depicting the #9 with the front knob, either they have not updated their pics, or they are selling old stock.
-Andy
tnimble":29mjcyaz said:My point was that the versions of LN which did had the front knob are the odd ones. Leonard intended the plane to be held by the casting itself. No knobs at all.AHoman":29mjcyaz said:I'm not sure which site you are viewing. On the LN site, you can see that the knob on the side of the front of the plane is now gone. The hotdog, which used to be optional, is now included as standard. If an online store is depicting the #9 with the front knob, either they have not updated their pics, or they are selling old stock.
-Andy
The knob at the back was later added to prevent your hands getting nicked by the back of the blade. The hotdog was added to give more heft to the side of the plane.
When using the no 9. one hand should thrust the plane forward from the back. To get more siewards pressure on the shooting board use the hotdog handle.
The knob at the front that is screwed in the side (or top/bottom depending on how you see the normal plane's orientation) was added by some users as a custom mod and LN 'copied' that on the first models. Why did mister Bailey not have that front knob? The knob is far above the center weight point of the plane. On the shooting board this tends to tilt the plane unless you also press down to compensate. More force needed more firction, less controll.
tnimble":1goastuv said:When using the no 9. one hand should thrust the plane forward from the back. To get more siewards pressure on the shooting board use the hotdog handle.
I can only reffer you to the Stanley and Bailey documentation on the plane.karl":19dxeeer said:I don't believe the knob (or the hot dog handle for that matter) were put there to increase the users ability to apply "sideways" pressure. They are to ease the pushing of the plane to and fro.
The hotdog is just above the weight center, a front knob even higher and puts load effort on the plane.Using either the knob or the hot dog handle to apply sideways pressure will result in tipping of the plane.
Personally I always preferred the knob.
I've always thought the No9 a bit overrated, so I sold mine and bought a Philly Mitre - just as good, at a fraction of the price.
No, as stated that would centainly not work or would be very counter productive to re-clamp the piece after each stroke. (Unless the board is somehow spring loaded)Tony":19dxeeer said:This doesn't make any sense to me. I think you are saying that one should use two hands to push the #9 on the shooting board, one at the rear and one on the hotdog, which is not possible uless the wood is clamped (which is isn't on most shooting boards)
The rear knob is not meant to be grabbed like with the knob of a bench plane. The knob is to prevent the hand from getting nicked from the back of the blade. Your fingers and fonrt of the palm should rest on the lever cap with the knob at the back ( near the wrist) of palm.I have tried pushing te plane from the rear and this does not work well at all - on the LN, both the front knob and the hotdog are positioned nicely to allow the user to apply pressure where the blade meets the wood
